Old 02-24-2015, 09:03 AM   #14 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I would suggest to watch temp and your radiator fan, because it doesn't have to be that your engine temp wil rise if your fan is running full speed. But that will affect your FE anyway because of more power needed by the alternator to run the current needed.
You'll find some info here Radiator fan activation temperature
I've connected a red LED with 560ohm resistor in line to see if my fan is kicking in. If the fan is running too much you can open a bit your grille block and let the air to pass it more freely. By trial and error you'll find the best cover size for your grille.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
jimsiggy (02-24-2015)
