03-14-2015, 12:01 AM
#360 (permalink)
Changfa diesel + Suzuki
Centurion - '74 FIAT X1/9 Centurion Full Race DNA Last 3: 143.5 mpg (US)
Originally Posted by rustygirl
I'm down south in york, pa.
Cut the red wire, that fixed bridget. Oddly all the important lights still work. Hav you given any thought to an alternator delete switch? Won't help the fuse issue but may help mileage. I'm going to disconnet the electric fuel pump and if the mechanical pump can feed the engine i may try it.
rustygirl,
Yes, I have an alternator cut and used it last year - I recommend it.
As long as your fuel level will gravity feed to the mechanical fuel pump you should be ok. If you want to give it a test, unhook your elec fuel pump, then go find a steep uphill. If Bridget starves out for fuel, then your mechanical pump can't lift very well and you'll need the electric also. I have both (same as you) but Centurion's fuel tank/fuel level is way higher than the mechanical pump's inlet so the electric is primarily used during a fuel filter change or to purge the system of air..
Can't tell from your photo - but do you have a decompressor?
The fuse issue here is in the glow-plug and starter solenoid loop. New glow plugs may be a little "hotter" than the 1981 model, and the solenoid may have taken on some condensation - will deal with that tomorrow.
The clutch master is the original 1966 unit so it's due for rebuild or replacement. Time to throw a blanket over the baby and call it a night
~CrazyJerry
