Thread: tdi bug
Old 03-25-2015, 06:03 PM   #10 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by arcosine View Post
5 speed.
Nice! Good to see another TDI on here. X2 the fill neck mod. Lets you fill at least another gallon and it is easier to get consistent fill-ups IMO. Diesel foams in the filler neck and it is hard to tell when it is really full. You can also hold the nozzle against the button as you fill but why not just pop it out? I would also recommend a FrostHeater, especially if you have to park outside. It speeds warm-up times which is good for mpg but also makes starting easier. These diesels don't make heat very quickly untill you put a load on them.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
