Daox, can you also take some pics of the light cutoff and the color? I usually like the 5k color temp. but every manufacturer has their own version of color temp. Also, it would be nice to see a good cutoff, so we're not blinding anybody.
Thanks!
EDIT: You should also consider getting a ballast. That will help with the longevity of the bulbs as well as keep them from flickering at a noticeable rate.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
