Old 06-25-2015, 12:23 PM   #50 (permalink)
oil pan 4
I still use the stock non turbo injection pump from my original 6.2L engine on the twin turbo 6.5L, its turned up a little but not all the way. The old 6.2L would smoke some, now with the same injector pump setting with 2 turbochargers force feeding tons of extra air into the engine it only smokes a little if I stab the petal with my foot, with the vehicle in neutral or park. The non turbo injection pump will work perfectly fine.
Don't worry about running lean, diesels always run lean.
If there are any doubts about how well the 1.6L engine can handle a turbo, use an intercooler for sure.
