Old 07-01-2015, 11:26 PM   #5 (permalink)
oil pan 4
If size matters the prox you want is an IE5366 its tiny. The sensor its self is only about an inch long. (this is tiny compared to the IE5295).
I believe they use a female pico (8M) type cord. I don't normally use these so I will need to double check to make sure these take the pico cord.
If 1 inch over all element length is too short for you then there is IE5349, its about 1-3/8 inches long.
These inductive proximity sensors can get a lot smaller than this.
