Old 07-15-2015, 03:03 AM   #4 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
What were your actual A, B, A readings?
What did the ABA test consist of? Grill block vs non grill block vs grill block?
Grill block/higher psi vs stock vs grill block/higher psi?
So im assuming A (grill block/higher psi), B (removed grill block and lowered psi), and A (installed grill block again/upped psi)?
Comparing ABA results to "previously recorded readings" kinda defeats the purpose of ABA testing because there are an infinite number of variables between the ABA tests and the "previously recorded readings."
ABA testing should show the effectiveness of the grill block mod or increasing the tire psi independently
**not trying to be mean, just trying to promote good test taking procedures and results**
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
UltArc (07-15-2015)
