Old 09-01-2015, 01:25 AM   #25 (permalink)
Rango318
Geoff - 5 speed swap - '02 Volkswagen Jetta GLS TDI
Diesel
Team Turbocharged!
90 day: 49.46 mpg (US)
Fusing Titanium - '19 Ford Fusion Titanium
Team Ford
90 day: 50.91 mpg (US)
Originally Posted by deejaaa View Post
what did you attach it to?
do you think it's possible if I try using just the ramps instead of lift to install?
are you going to enclose the back section?
I used self tapping screws to screw into part of the frame, and a few other random places I thought would help keep it attached.
I had tried using ramps and jack stands the first time, and it was almost impossible. Using the lift, and an extra set of hands, made it so much easier, I can't even describe.
I would like to enclose the back, but I will need to find more material. I'm on the lookout for another truck bed liner, because it is very strong, and I think should help channel the air straight out the back.
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
The Following User Says Thank You to Rango318 For This Useful Post:
aerohead (09-01-2015)
