08-31-2015, 12:53 PM
#21 (permalink)
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
08-31-2015, 12:54 PM
#22 (permalink)
The Following 2 Users Say Thank You to Rango318 For This Useful Post:
08-31-2015, 01:55 PM
#23 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
what did you attach it to?
do you think it's possible if I try using just the ramps instead of lift to install?
are you going to enclose the back section?
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
08-31-2015, 02:36 PM
#24 (permalink)
Nice & clean, like it !
The Following User Says Thank You to euromodder For This Useful Post:
09-01-2015, 01:25 AM
#25 (permalink)
I used self tapping screws to screw into part of the frame, and a few other random places I thought would help keep it attached.
I had tried using ramps and jack stands the first time, and it was almost impossible. Using the lift, and an extra set of hands, made it so much easier, I can't even describe.
I would like to enclose the back, but I will need to find more material. I'm on the lookout for another truck bed liner, because it is very strong, and I think should help channel the air straight out the back.
The Following User Says Thank You to Rango318 For This Useful Post:
09-01-2015, 11:11 AM
#26 (permalink)
Not banned yet
how much weight do you think was added?
when are you taking it out for a test?
apologize for all the Q's but I want to do this also.....
09-01-2015, 12:01 PM
#27 (permalink)
Not a problem about the questions.
Total added weight was somewhere around 10-15lb. Not much. The bed liner is very light weight. It is very strong when you try to bend it against the ridges, but it flaps around easily with the ridges. I'm sure it wasn't much weight. I could have done it myself, held it up and screwed it in, but it was awkward to hold, and why not take the help if available.
Its being tested now, but I don't do short trip tests. I usually do full tank tests, but this time I will be filling early, right before TDIFest. Also, my results are going to not be accurate because I also switched to new rims and tires when I did the pan. When i get and numbers I will let you know.
09-01-2015, 01:29 PM
#28 (permalink)
Not banned yet
thanks for the answers.
have you heard about adjusting timing using adaption? I did this to mine last week but only had 3/4 tank left so won't post results until I use a full one.
did you think about using this section for the rear?
09-01-2015, 09:18 PM
#29 (permalink)
I have heard about it, but I do not have access to a VCDS.
That section of the liner wouldn't have been long enough to cover the whole gap, and I don't have it anymore
09-04-2015, 01:37 PM
#30 (permalink)
My trip to TDIFEST in Maine was 908 miles on 15.654 gallons. 58mpg. Not bad for such wide and heavy tires
