Old 09-11-2015, 09:36 AM   #342 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by sqidd View Post
IMO building a jungle gym cage for 1-2 trips to the track a year is overboard. Unless I plan on spending a lot of time at the strip I go with the least complex cage I can get away with.
Street car first. Race car second.
I agree with you completely on this one. I just can't get my self to build a cage that will make the car not as much fun to drive on a daily bases. If I go and make it a full cage then I need to get all the other things certified. At that point I might as well remove a ton more weight and make the car run low 9's. Then I will have another tin can race car that won't be used much anymore. I always got to stay focus on what I built this thing for, to be ran all seasons and to work on FE strategies.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
jedi_sol (09-17-2015)
