Old 09-15-2015, 12:58 PM   #33 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Granted@ em setting( this won't happen).
max boost can be pushed past the systems capacity to yield higher pressure. The increase in pressure is from heat 450°+iat.the same volume of air is pushed in just expanded (less efficient) to combat this problem an intercooler is used (larget than stock. Or more than one cool cooler.)
Increase iac=increased egt =Faster spin on turbo(expanded exost gas) this can snowball quickly into melted pistons.
My 91 dodge stock as Cummings built it.
I see this on long hills w/ac on my intercooler gets heat soaked from the condenser. I'll pick pu 100°-150°f on my egt meeter
@wot I. See the turbo lag on egt meeter egt will spike to1100°f and as pressure increases (engine leaning out) egt drops to 1000°f.
At idle(cold in park grid heater on)250°w/ac+25°
Idle (worm) 275°
Idle (cold hot in gear)300°
Compression breaking. 150-200° and 2 psi boost (reason over feeding o2 as stated by others leaner is colder)
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
