Old 10-02-2015, 03:29 AM   #331 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Originally Posted by hardline View Post
Havent topped 2500 RPM in months? I should take you for a drive in my ZX2. 8200 RPM redline, yessir.
That would be awesome! I did get the car up to roughly 2800 rpm today. I got up to 75 mph on the highway trying to burn some of my carbon out
Originally Posted by pgfpro View Post
100 kilopascal = 14.503773773 psi
This way you don't use two measurements (inch/hg verses psi) just one
I hear ya!
So 100 kpa is equal to 1 atmosphere roughly, at sea level. Going from the previous post about making power in lean burn, you can make the same power running 22:1 AFRs @ just over the atmospheric pressure, slightly less than 1 psi, as you can in running in vacuum @ 14.7:1 AFRs. And with these benefits -
You will also have a 6.4% decrease in fuel consumption and a 28% decrease in combustion temperature. Plus a 4% increase at P3 compression while maintaining the same P4 pressure.
Incredible!
I may have found a turbo - 240sx Oem Nissan S14 SR T28 ballbearing turbo
It is a turbo off of a Nissan 240sx, comes with the t28 ball bearing turbo, which is in excellent condition, oem manifold, oem turbo elbow, intake inlet, and steel braided oil and coolant lines. $250.
Maybe good, maybe no? Here are the specs. It could be either of these.
S14 Zenki (1993-96) Black-Top T28:
Compressor: T-28, 60 trim 60 mm 0.60 A/R BCI-1 compressor in T-04B housing
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Stock Boost: 7 psi
Safe Boost: > 13-15 psi After that The Turbo is past it's efficiency
Max Boost: 17 psi
HP Ratings: 250 - 260 RWHP
Type of Bearings: Journal Bering
S14 Kouki (1996-98) Black-Top T28:
Stock Boost: 7 psi
Max Boost: 17 psi
HP Ratings: 255 - 265 RWHP
Type of Bearings: Ball Bearing
From what I understand about turbos (which is very little), this is quite a small turbo. It is smaller than the FP Red you mentioned earlier in the thread. Does that mean it will make boost easier and I should go with one slightly bigger?
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following User Says Thank You to BabyDiesel For This Useful Post:
MobilOne (11-13-2015)
