Old 10-07-2015, 05:41 PM   #53 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by The donkey CRX View Post
I got both of the pads from Amazon. The one on the oil pan is 250 watts and on the transmission is 100 watts. They both seem to be enough to heat the oil to 280 degrees in 2 hours. Both come with an adhesive backing included. The kits also included the blue silicone chalking you see that seals the edges.
I'm surprised, as I have a 400w block heater installed and even overnight, and when the temperature is around freezing, it only gets up to about 50c.
I'll probably go with similar sizes though. Thanks!
The Following 2 Users Say Thank You to Ecky For This Useful Post:
TDFbound (11-20-2018), The donkey CRX (10-08-2015)
