That's great Ecky. I think the 2000 Insights do go into lean burn easier and each model year and recall upgrade after that added parameters for lean burn to cut back on NOX.
Our VX's only require a water temp above 145 degrees for lean burn and of course no NOX purge cycles either.
Reason: VX for LX
