Old 10-10-2015, 06:11 PM   #14 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by ecoboy View Post
Thanks Ecky,
Good to know a 3 cylinder is up to the job. Wonder how much the assist helps the insight. My guess would be alot.
I found this guy, goes by the name of Geo Jeff. I guess he is the master of metros maybe I will contact him as the only ecobox near me is a metro.
The electric motor doesn't provide much extra power at the top end (you only get ~73HP at redline, assisted), but the little 3-cylinder with assist puts down 91ft-lbs of torque @ 2000RPM while assisted. It makes the 1850lb car quite drivable below 2000RPM.
EDIT: It's worth mentioning that, even under the super rare circumstance of a catastrophic failure in the hybrid system, unlike a Prius, the Insight can continue to run as an ICE-only car.
