Old 10-13-2015, 03:39 PM   #361 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by jedi_sol View Post
so eventually you'll be able to run 100% fuel solvent? as in "free" gas?
Yep did a test yesterday, just a quick drive around my test area on 100% waste solvent. Made a global fuel enrichment adjustment in the fuel map and it ran great with no problems. I set the stioch at 13.7 A/F based on Toluene and Acetone. Also ran it up to 25:1 lean burn and it seems it has more power then normal pump fuel?
Pressure Gradient Force
The Positive Side of the Number Line
