Old 10-15-2015, 03:50 PM   #2192 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by MPaulHolmes View Post
Notice that the power board is designed for 3 separate phases, with 2 IGBTs (to form a half bridge) per phase, plus 4 IGBTs for the boosting section. That way you could boost, say, 150 amps (shared between 2 IGBTs) at 150v up to 75amps at 300volts. Then the 300volt section would be happy with 1 IGBT, and the low voltage section would be happy with the 150amps shared between 2 IGBTs. Then, to minimize the stray inductance, the driver board mounts perpendicularly to the power board, and the IGBT legs get soldered directly to the driver board. So, the driver board is designed to fit exactly with the footprints of the to-247 IGBTs. The IGBTs get clamped against the base plate with the mounting hardware accessible, "south" of the power board. The legs get bent at a 90 degree angle, and go through the power board, stick through and get soldered to the driver board. It should work OK with 247C and 247D length legs.
Also, notice that the power board accepts either 16 film caps or 8 film caps and 8 electrolytic caps. Exclusive use of film caps would allow for switching at maybe 700v.
Also, notice that 2 of the current sensors are on the power board. There's a new type of current sensor that goes up to 100amp, and is only $8 each, and has a response time of like 1uS. So, 2 of the phases are monitored cheaply (and that's all you need). An external sensor would be needed for the boost section for hardware overcurrent protection. To keep things small, you have to solder the 6 gauge or whatever cable to the surface of phase 2, and to the boost section.
Doing it this way makes the size about 12.35" x 3.6" x 3.6" or so, so it's pretty small and not much wasted space. The down side is it's very much not flexible, but there is no wiring and twisting wires to the power section. The nice thing is, it's really cheap, about as cheap as I can make it.
I could have the 2 microcontrollers speak if I doubled up on the PGC and PGD, which means adding a switch after it is programmed. But then that means possibly changing the pins of the debugger (you have 3 choices for the 2 debugging pins). I could then do the throttle & brake & temperature & temperature2, & voltage on the dspic2010, but would have to send the data to the other one. That means adding voltage monitoring, which adds around $15 or so cost, which isn't bad. There's room on the control board.
The control board is going to be cheap to make, so I could make the other changes later too. I was just trying to do "good enough" for as cheap as possible, without too much extra complexity. I guess I started worrying about messing with PGC and PGD and debugging and sending the important things like throttle so that the dspic4011 then had 2 separate UART conversations going at the same time (uart1 and uart2).
Very cool.
If you're boosting the voltage, don't you have to measure bus voltage at some point? It would seem to be a necessary part of the whole thing. Also, I was hoping to use some of the BMS information for these things. Yes, there will be a voltage drop, but we're talking a few volts vs 650V.
I really like the **ability** to make a 2 layer board. It would be really easy to add a shield if noise is an issue.
I really like everything about this, but I would like to change the capacitor - maybe in a "high performance" version.
I've been warming up to the idea of those smaller package switches. How about this for an idea for a "performance" version:
- Base it on those big cylindrical capacitors.
- The app notes for the caps talk about using sheets of thin metal sheets rather than thick bars to transmit the electricity. By making them parallel and close together, the inductance is dramatically dropped. I've been trying to figure out how to really do this. The suggestions in the app notes are ok, BUT
- Use lots of little TO-247's to pull this off, instead of big IGBT's:
- The high side and low side bus sheets are round disks. The TO247's are attached to the top of one disk and the bottom of the other disk in a circular arrangement with the legs facing radially out. (high side and low side) Using isolated TO247's would allow the switches to be connected directly to their corresponding plates. The control leg would be bent up ( through holes in the plates ) to connect directly to the control board.
- between the plates is a piece of insulating plastic that has channels for cooling oil! The bus plates would also be the cooling system! This would also solve the problem of cooling the bus bars and cooling the capacitor.
Yes there are some assembly issues. Perhaps these could be worked out - like soldering the whole mess in a toaster oven??
Thoughts?
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (10-15-2015)
