Old 11-16-2015, 12:58 PM   #19 (permalink)
oil pan 4
Remember an actual dedicated manual steering apparatus tends to have around double the mechanical advantage as a powered unit.
Now adays its almost impossible to turn the steering wheel on a power steering car because most OEMs use approximately between 12 and 14:1 gearing and a 14 or 15 inch steering wheel.
In the days of manual steering the mechanical advantage of the steering apparatus was about 25:1 and the steering wheels were big, typically around 18 inches in diameter.
I am running my 3/4 ton suburban with the belt off the P/S pump. It has most of the weight of a camery on the front axle and I am doing alright.
The people saying that the camery is dangerous with no P/S are just completely ignorant of the situation or have the upper body strength of a tea cup poodle.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
JMunn55 (11-17-2015), MobilOne (05-15-2016)
