I have 90 watts installed as of today, which given the dreadful weather forecast for Monday and Tuesday is 40 more watts then I was planning on adding.
I am thinking that 50 watts is all really need for just going to and from work.
With the MPPT charger and over paneling I don't need to worry about not getting enough power.
These solar panels are sitting flat, just by them selves.
In the summer while at work I plan on parking next to a building to block the sun later in the day.
The bags of lead shot squish the RTV that holds the panels on nice and flat, also ensuring a good seal. Only problem is 3 bags weigh up to 75lb.
Setting 3 panels at once requires around 200lb of shot placed on the roof (some of the bags are no longer 100% full).
You don't have to use heavy lead shot. A sand bag should work just as well.
