Originally Posted by oldtamiyaphile
It may not look OEM but the dash top is the best place,
As long as you can shield it! (se my post above) MJC
It followed by the top of the steering column. If you guys have 'Blu-Tack' that's used for sticking posters etc up, that will let you mount it to a curved surface and still be easily removable.
I've often thought covering the SG with a second dash top pod from a wreck would be the way to go. You could possibly also use something like a motorbike helmet, suitably cut down
