Old 01-14-2016, 02:05 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by oldtamiyaphile View Post
It may not look OEM but the dash top is the best place,
As long as you can shield it! (se my post above) MJC
It followed by the top of the steering column. If you guys have 'Blu-Tack' that's used for sticking posters etc up, that will let you mount it to a curved surface and still be easily removable.
I've often thought covering the SG with a second dash top pod from a wreck would be the way to go. You could possibly also use something like a motorbike helmet, suitably cut down
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-14-2016, 02:18 PM   #12 (permalink)
90 day: 57.73 mpg (US)
The top of the Firefly's cluster is also very rounded, but the gauge is happy there with a single point of contact. And I'm still on my original 1-piece of velcro on the dash that came with my ScanGauge-1. The adhesive hasn't melted/slipped.*
(Eastern Ontario climate)
Old 01-14-2016, 04:56 PM   #13 (permalink)
mcrews's Avatar
that's like saying "southern North Pole"!!!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-14-2016, 06:48 PM   #14 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Whatever velcro they include in the box with the Scangauge is amazing stuff. It stayed on top of my Civic's dash for ... 6-7 years intact. In Texas.
I bought some generic self-stick velcro for the Fit and it's not nearly as good. The adhesive gets soft and "oozes" sideways out of position.
I have it on the steering column just below the speedometer. The cable comes out to the right just below the dimmer knob. I have a block of foam under it to hold it up so it's visible, and velcro on the back to hold it against the panel. It's angled back a bit, but still visible and viewable.
Old 01-15-2016, 05:02 AM   #15 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
IDK, we have as much sun as Texas and I don't have a problem with glare, overheating or adhesive letting go (my shielded GPS sometimes freezes when too hot by comparison). A shield would still be nice and could be as simple as a round plastic ice cream container, maybe covered in leather to give it an OEM 'grain' finish.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
mcrews (01-20-2016)
Old 01-15-2016, 10:49 AM   #16 (permalink)
Hypermiler
Wagons
The Following User Says Thank You to PaleMelanesian For This Useful Post:
Andrei_ierdnA (01-24-2016)
Old 01-15-2016, 08:26 PM   #17 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Custom made with fiberglass cloth and fiberglass resin
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following 2 Users Say Thank You to jedi_sol For This Useful Post:
Andrei_ierdnA (01-24-2016), mcrews (01-15-2016)
Old 01-19-2016, 07:35 PM   #18 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Very nice! Did you use SG as the mould or did you use another technique? Would you mind to share the knowledge?
The Following User Says Thank You to seifrob For This Useful Post:
jedi_sol (01-19-2016)
Old 01-19-2016, 07:54 PM   #19 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
here's my install on my 2013 Subaru WRX Sti
1) tape up the scangauge using painters tape
2) tape up the gague cluster shroud using painters tape
3) apply fiber glass resin
4) apply fiber glass (2-3 layers)
5) let dry
6) remove the hardened fiber glass
7) remove the scangauge
8) trim, sand, paint
9) i used double sided duct tape to attach the fiberglass to the gauge cluster shroud. It has held up for 2 years in So. Cal heat.
The Following 3 Users Say Thank You to jedi_sol For This Useful Post:
Andrei_ierdnA (01-24-2016), Joggernot (01-20-2016), mcrews (01-20-2016)
Old 01-20-2016, 12:28 AM   #20 (permalink)
mcrews's Avatar
jedi,
thanks for reposting w the instructions!
Ive never played w/ fiberglass....but your project makes me WANT to!!
ECO MODS PERFORMED:
First: ScangaugeII
The Following User Says Thank You to mcrews For This Useful Post:
jedi_sol (01-22-2016)
