Kill switch!
I pretty much followed Daox's example exactly except I decided to mount my kill switch to the dash next to the cruise control because there are extra blank pieces.
http://ecomodder.com/forum/452430-post91.html
1) remove steering wheel under cover. There are 3 screws on the bottom, then gently pop the cover off.
Then put you hand in that big hole on the left and pop out the blank cover piece.
3) for the kill switch I'm using a brake switch that I used for my old del Sol and Sti projects. I drilled a hole and poked it through.
4) Finished! Nice and clean, just how I like it
![](http://i101.photobucket.com/albums/m65/jedikn1te/Geo%20Metro/20160205_023215.jpg)
