Old 02-11-2016, 09:33 PM   #53 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by me and my metro View Post
I think you will find a cable operated clutch in your Metro. Is there free play at the top of the pedal travel? The clutch is easy to adjust, right on top just behind the radiator.
You're right, I guess the Geo is cable clutch. The only reason i thought it was hydraulic is because every old Honda that i've driven with a cable clutch, the clutch pedal was really hard to push down. Since newer Honda's switched to hydraulic clutch, the clutch effort was way easier.
Since the Geo clutch is so easy, I just assumed it was it was a hydraulic clutch.
Yes, there is about 1 inch of free play at the top of the clutch pedal. I'll look into adjusting it.
UPDATES: I used the kill switch more generously for my commute to work: 65mpg! Previous best was 61mpg.
So with only 2 mods (fixed a broken exhaust and kill switch) i've improved mpg by 18%
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
