Thread: HCH1 Ecomodding
Old 04-26-2016, 01:42 PM   #31 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
After going over the car carefully, I'm inclined to believe I'm missing a few bits:
1) Under-engine panel, which is part 74119-S5B-000 on G1part.com, and around $40. Anyone know where I might get one of these for cheaper?
2) 74306-S5A-J01 - MOLDING ASSY., R. ROOF - rubber bit that runs along the roof seam. About $25, but I bet I could steal one from any same-gen Civic from a junkyard.
3) I believe there should be a plastic liner or cover behind the passenger rear wheel well, over the muffler. There's currently a gaping hole instead. I was unable to find this part on G1parts, could anyone give me an idea of what it's called?
I think you could fabricate #1 with coroplast for much cheaper than $40. And #3 could also be fabricated, maybe using sheet aluminium if the heat makes you nervous. I agree that you could get #2 at a junkyard, as long as you are sure to differentiate the sedans from the hatches from the coupes and get your identical body type.
