The mechanical thermostatic valve is mechanical and regulates the air to around 90°F. this would work . or is it oil pan"The way GM did it there is a pnewmatic thermostat that opens and closes a flapper on the air cleaner intake tube. So it would go back and forth between 600'F air and cold air. You cant tune for that".. this wouldn't
The electric portion only reverts it to cold air.
You don't have to use the cold air.
I thought about restoring the OE thermostatic intake but I wanted something a little different.
Main difference with mine is I was never trying to flow full air flow through the WAI.
If I need power the CAI is opening.
Also I am going to be running 11:1 compression.
I will end up using 2 snorkels too.
If it gets so cold there why not just convert to an after cooler and just turn off the after cooler when it's really cold letting the turbo heat the air? While drawing air from under the hood.1)my Air to air will drop the temp to ~-40°f @60+mph at idle.2) I have my complete turbo up. Heat wrapped so after 100mi I can pop the hood and hold on to the turbo or "anything" without getting burnt (below~130°f) and this is with a 4-500°f EGT at the time(inside the manafulld). So no under hood heat to help. I was going to pull my warm air off the down pipe.3) thire is no heat produced by the turbo or under the hood with EGT of 50-150°f and no boost at idle.
That is what I was going to do when I thought I was moving to Montana or Wyoming.
Have you read the 5.9 stationary non intercooled application manual?
They recommend running cold air down to 25°F to freezing, then drawing air from inside the enclosure if operated below 25. this to keep the air form becoming too dense causing excessive back presser on the exost side of the turbo or stretching the head bolts. And the injection pump is calibrated for IAT~2-400°f and steady rpm @~rated (1600rpm)
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
