Old 06-05-2016, 07:39 PM   #16 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by hayden55 View Post
I don't have a GPS but I used a Tremec gear calc and heres what's odd:
Speedo and RPM read ~74-75mph and ~3150ish rpm which is clearly wrong as im traveling 70mph.
From tremec's website the car should spin 2960rpm at 70 and sure enough with no offset, the scan gauge read 70mph @ 2960rpm. So goofy gauges, but the obd2 signal to the scan gauge is 100% correct.
You are saying that Tremec told you 75 mph and the OEM speedometer read 70mph and the scan gauge read 70 mph? If so, you have your Scangauge speed reading calibrated, but the car might be giving your gauges incorrect information because of tire/wheel size. What size wheels/tires are you running?
