Old 06-22-2016, 06:20 PM   #2 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
here I did alittle research for you........
"Type of Engine
These spacers mainly benefit older engines. In particular, those with fuel injection systems that have the fuel go directly into the throttle body, where it then mixes with air before going into the combustion chamber. It also can help with carburetor systems. However, if the vehicle has a multi-port fuel injection system or other top of the line system, then that small change in the air vortex will not make any difference to the performance, torque or horsepower. Therefore, before you go out and purchase a spacer, make sure your engine can actually benefit from having this upgrade."
I believe the answer is NO.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following 2 Users Say Thank You to mcrews For This Useful Post:
Joggernot (06-23-2016), Xist (06-22-2016)
