Old 06-30-2016, 01:51 PM   #11 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Natalya View Post
...1: I don't know where to find a +5v source, hence the regulator device. If I knew where one was I'd use that instead.....
The connector known as P31 toward the rear of the seat back has at least one 5 volt signal on it. You will have to check the shop manual for this connector since I am at work now. P31 is connected to the module that sits on top of the IMA on the right side when viewed from the rear of the car.
I just saw Sam's post on this. Thanks Sam.
Jim.
The Following User Says Thank You to 3-Wheeler For This Useful Post:
Natalya (07-01-2016)
