Old 07-16-2016, 12:04 PM   #94 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by RustyLugNut View Post
We have several members on here that have the tuning and fabrication capability to use this tool effectively. It has value.
I'm sure that the member here who keeps posting about the benefits of HHO without, you know, actually backing himself by posting hard data about his setup and the results he got with his setup, will step up to the plate and use his tuning and fabrication capability to prove that HHO works.
Can't be hard to do. He already claims to have a modified Dodge Magnum R/T with factory-installed MDS cylinder deactivation, and is willing to prove how much better his HHO setup is over my 6-speed manual transmission setup by engaging in an eco-drag race (whatever that is) with me. Surely, somebody who is capable of modifying a Dodge Magnum, is also capable of building and testing a workable HHO setup.
What this forum needs is a definitive answer to any and all who ask, "does HHO work"? No one has done that work because the hubris and lack of understanding on this forum will not allow it.
Step up to the plate and provide it, then. Quit whining about "hubris and lack of understanding," build your HHO generator, and demonstrate that it works! You know, you mentioned something about those other "several members on here that have the tuning and fabrication capability." Each of them were perfectly capable of building their own eco-mods, testing them, and publishing the data here. You should do the same.
Unless you're just wanting others to do your work for you. Or maybe you just think the other "several members on here that have the tuning and fabrication capability" aren't good enough because you yourself haven't "vetted" them.
The Following User Says Thank You to t vago For This Useful Post:
mcrews (07-20-2016)
