Old 07-16-2016, 08:17 PM   #77 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Freebeard this is why I joined...I know a lot but I'm not a know it all. Thank you for the advice.the math required to do that by hand is beyond me... I had to build my canopy before I could wrap my head around how to draw it on paper. (Yes draw as in pencil and paper )I waited till it was built to start reaching the site for ideas to keep the idea pure and mying..as it turns out the way I "see"air flow matched the temple(I was off a small amount) . My uneducated guess CAN be close.as you can see from my V1 canape
The faucets are a result of using only 5 spars onV1 (hence the volume of supporting members suggested was for consistent raidi not strength) current V 1.2 they are reduced the only change to the skin support structure is the addition of 1/2" fome. Resulting in ~12"R insted of 1/4"R
V1.2
The way I've seen the boat wrap work each geometric panel would form a flat panel from bar to bar as in on V1, I could be seeing it rong.
How much would such a geodesic 1/4 dome weight in lbs made of 1/2 .095 round =.41lb/ft bair ,strong enough to hold out a road closing snow storm in the Sierra Nevada(10+feet in lessthan 6hrs.) I'm at 35lbs wraped
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
BamZipPow (07-18-2016), skyking (07-16-2016)
