Originally Posted by cowmeat
I bet it would still do over 90 mph if you took dropped in the guts from my Insight!
Well, you're halfway there...
Power needed to overcome aerodynamic drag is proportional to speed cubed. At higher speeds, rolling resistance is a small factor and can be ignored to get a close approximation.
Assuming it takes 190hp to go 260mph in this car, 80hp (67hp gas engine, 13hp electric motor) will get it going... ~195mph.
It should do 90mph using just the electric motor from the insight.
