Old 10-12-2016, 09:40 AM   #95 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
After sleeping on it, I'm inclined to think that your low battery voltage, random dying, and misfire codes are probably all part of the same problem, and it sounds electrical.
This is unlikely to be your issue, but I had a fuse that had a bit of corrosion in the fusebox which was causing a lot of wacky behavior with my radio and 12v socket. Replacing the fuse cleared this up.
Daox (10-12-2016)
