Old 11-11-2016, 08:57 AM   #139 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Originally Posted by Macskyver View Post
Thanks.
How well does that work in practice on large surfaces? I imagine you can't easily get mylar in a large enough single sheet to do a camper shell. Also, how thick are you doing the epoxy? Is it still the multiple thin layers or a single thick layer?
Here is a link to the thread where we discussed it.
http://ecomodder.com/forum/showthrea...yup-20811.html
The mylar would never conform to a compound shape. It is rigid in-plane so you can bend radii and such, but curving in that other direction won't work.
I put down a layer of cloth, wet it, put the mylar on and squeegee over the top of the mylar. This removes huge quantities of resin out the edge, and results in the lightest possible smooth layup. I mean, glass-smooth, and as little resin as possible. The mylar acts to compact the cloth.
It is a poor man's vacuum bagging setup.
I plan on using it whenever I can.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 3 Users Say Thank You to skyking For This Useful Post:
BamZipPow (11-11-2016), freebeard (11-11-2016), KamperBob (11-12-2016)
