Old 11-23-2016, 05:13 PM   #57 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The engine will actually be most efficient at low vacuum, probably 3-5 Hg. High vacuum means low load, which is less efficient but uses less fuel with the same gearing. It's generally better to be in a higher gear with less vacuum than lower with more.
