Originally Posted by serialk11r
Wow, you actually did the P/S delete. Hats off to you. That's a heavy car to drive with no P/S.
Damn right it is! 3371 lb curb weight, and 62%(?) over the front wheels. It's tough. They don't call it armstrong steering for nothing!
Now I have no excuse to not do a P/S delete on my car which has half the weight over the front axle...
That's right...Well, except you have electric power steering, so it doesn't hurt that much.
As for your injectors, those diagrams have 6 wires for the injectors, and there's nothing that obviously looks like it will shut all 6 down. Try to find which "box" those wires are coming from and check what it controls, if it's just the injectors you can cut power to that box, otherwise I think you'll have to tap relays into all 6 wires.
I'll look into the other wiring diagrams further, see if I can spot C101 anywhere else. I REALLY don't want to have to cut into the 6 injector wires.
Forgot to mention that I am back working at an auto shop. I love lifts.
An important thing to note for anyone considering doing the belt swap with the same accord is that the belt isn't routed the same way anymore. I have diagrams here to show what I mean.
Stock
Modified
