Old 12-30-2016, 11:48 PM   #62 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
it is easy to tell.
The biggest problem will be the strut tower. is it over the tire or behind the tire.
On my Q45 the bottom of the tower was just over the tire. I only had about 1" of clearance.
you should be able to feel around the tire and see what parts are close to touching.
btw, my tire guy mounted up the size I wanted (before I ordered the set of 4) and made sure it didn't hit anything. your tire guy should do that if you are a good customer.
and yes, I was VERY pleased w the results of 'upsizing' on the Q45. Better mileage, better look, little better ride(Q45 had electronic shocks so it had a pretty smooth ride to startwith)
good luck!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
