Old 01-22-2017, 11:06 PM   #11 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Nice result! Remove the power steering pump belt. It was an option on these little car. I have driven without it for years. It should be worth 1-3mpg to you. If you can't adjust yourself to manual steering after a while, you can just put the belt back on. Also... keep up your tire pressure to at least max sidewall ratings. Even on snow tires it should make a difference.
