Old 01-29-2017, 10:44 AM   #18 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Civic98lx View Post
I have an obd 1 car also. I bought it for that but wanted to see how it compare to the obd2 ultragauge reading. I'm still playing around with the ultragauge display gauge, I "think" there is an engine load % option I could select. Much like the throttle %.
Thanks for the link, I will read up
Oh, yes. Very cool. You Could compare engine load readings on the Ultragauge with vacuum readings on the vacuum gauge. On the UG, which I also use on a 98 Civic, there is both a throttle % and an engine load%. You want the latter. Throttle does not help much. My 98 non-vtec Civic engine (sames as you LX) likes 75% engine load (70-80% is a fine range for most ICE vehicles). What is that on your vacuum gauge?
