Old 08-15-2008, 09:39 AM   #2 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
The hatchback angle & design is quite different between the two cars:
The Pinto likely has attached flow partway down the glass, whereas the Swift hatch is actually designed to ensure the airflow separates as it leaves the roof line.
You'd be better off extending the Swift's roof line. EG: http://ecomodder.com/forum/showthrea...sion-3518.html
The 2.3% measured benefit of the prototype kammback isn't as large, but the testing was done at 55 mph vs. 70 mph for the Pinto. The kammback's benefit would be greater at higher speeds.
