Old 04-24-2017, 10:45 AM   #4 (permalink)
oil pan 4
To make any impact on fuel economy you are going to need to supply the electrical system with up to1kwh per mile. Or lets 50,000 watts continuously if you want it to be of any use on a hill.
Or around 25,000 to 30,000 watts or a half kwh per mile to maybe negate the trailers impact on vehicle fuel consumption.
You are better off focusing on the tow vehicl and trailer, mainly aero dynamics.
To give you an idea how much it would cost, just to put brake axles on my trailer it's going to end up costing up to $400 not counting the tires. And I'm doing almost all the work my self.
If you insist on doing this you are better off forgetting about using hub motors, because hub motors are expensive and proprietary. Just use a full floating heavy duty pickup truck axle. Because you know it can carry the weight and handle the drive torque.
Anything is possible with enough money.
