Old 05-29-2017, 08:51 PM   #5 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by fearlessjoe View Post
coasting in gear vs rolling in neutral .... for example
Coast in gear if you want to decelerate. Engine braking with fuel cut-off. RPM has to be above about 1200 RPM for fuel cut-off to work.
Use neutral if you're trying to maximize your coasting distance. Much longer coasts than you will get in gear = less fuel used prior to going to N.
