Old 06-13-2017, 05:01 AM   #57 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Originally Posted by Natalya View Post
Are you doing EOC by turning the key off or did you install a kill switch? I make a chip that tricks the ECM (when you press a button) into putting the car into Auto-Stop for EOC.
I know you don't have a good IMA battery, but there's a workaround that will allow you to use Auto-Stop (regularly, or with my extra switch) and will also give you Lean Burn.
What you do is you install a clutch switch that tells the car the clutch is engaged to prevent IMA assist. By doing this you can keep the car from trying to use the IMA battery, and therefore the car never learns the IMA is dead, so you don't get a CEL and the IMA light stays off. This unlocks lean burn and Auto-Stop. I can explain this in greater detail if you're interested.
I've been turning the key off to EOC. It is annoying, especially since the Insight's engine takes several seconds to die and I can't turn the key back to ON right away. Gaining over 10 mpg in town is worth it.
I have your chip on my wish list actually Money has been tight, hopefully I can place an order soon.
This is the clutch switch mod, correct? I've read about it numerous times on InsightCentral and is on the to-do list as well (I have a ton of things I want to do with my Insight lol). I'm definitely interested, so give me as much Insight into this mod as you can
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
