Old 08-18-2008, 08:39 PM   #27 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Originally Posted by donee View Post
Looking at your pictures more carefully, you probably do not need the two outside Airtabs.
Agreed there, after seeing the non-vg tuft results on the sides of the rear window.
Also, your spacing is much closer than recommended.
Actually, they were slightly wider than recommended (which is 4 inches on center from the installation PDF). These were set at about 4.5 inches on center.
