Old 06-17-2017, 03:34 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Are you getting DTC P0300? the random misfire, or are you getting one of the P0301-P0304 codes? Fuel injectors are only one of the explanations for the latter bunch, and the P0300 is not a injector code.
EDIT: Also... have you checked wires to the ECM/PCM for an open? The Honda FSM indicates replacing the ECM/PCM if the injector is not the fault and if there is no open between the injector and the ECM/PCM.
