Old 08-31-2017, 10:37 AM   #150 (permalink)
MetroMPG
90 day: 55.97 mpg (US)
90 day: 70.75 mpg (US)
90 day: 67.41 mpg (US)
2nd fill: 44 MPG
I need to calibrate the MPGuino, which means starting from a full tank, so I filled up. Results:
44 MPG US = 5.3 L/100 km
That's from the 3/4 full mark on the gauge @ 12.9L / 3.4 gal (US). So yes, it's a bit of a short fill, but I pumped until I could see fuel in the neck, as I did last time. So I think it's probably accurate.
6 mods in place: 50 PSI; AC/PS belt delete; partial grille block; passenger mirror delete; front license plate relocated, which was an aero disaster; pass wiper delete. (I'm still planning to start a dedicated MPGiata modding thread.)
Driving style: about 90% back roads driving (DWL), relaxed cruising on the scenic route (mostly with the top down) at 70-80 km/h (45-50 mph). EOC approaching turns, stops.
So it looks like 50 MPG is not going to be much of a stretch for a modded Miata in my usual driving environment.
wdb (09-05-2017)
