Old 09-20-2017, 09:16 AM   #26 (permalink)
oil pan 4
Head gasket patch is what you use to get the vehicle sold.
They don't work.
It's more of a temporarily repair till you can get it fixed right. This head gasket rear stuff doesn't stop the leak, it just slows it down.
Not fixing a bad head gasket as soon as possible will lead to cylinder wash down with coolant, which will taper it, then after you fix it you will be burning oil.
