Old 09-21-2017, 03:14 PM   #15 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by Natalya View Post
Compression looked good on all cylinders, highest was 165 lowest was 152. Going to take apart the upper part of the car again to get back at the knock sensors. Will test for corrosion on the block and shorts within the sensors themselves.
Also, unless anyone thinks it's a bad idea, while I still have the spark plugs out maybe I can spray some carb cleaner down in them to loosen some buildup if there is any, but I kinda doubt its bad at this point.
Compression sounds fine.
If you are going to loosen buildup, make sure you get it all out. You don't want it coming out when the engine is running.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
