Old 09-14-2017, 06:05 PM   #11 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
Knock sensor codes come in two varieties
Knock when none expected
No knock when expected
Also, as the knock sensor generates its own voltage, very little current flows through the wiring and it's extremely susceptible to noise. Make sure the shielding is intact and grounded properly
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
The Following User Says Thank You to BLSTIC For This Useful Post:
Xist (09-14-2017)
Old 09-15-2017, 10:35 PM   #12 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Found water leak, it's where I thought it would be, tube going to heater core at the firewall. Waiting until engine cools then I'm going to have at it.
Old 09-16-2017, 09:46 PM   #13 (permalink)
Engine-Off-Coast
Natalya's Avatar
Fixed water leak. Rented a compression gauge from the auto parts store.
What all do I have to disconnect to make sure I don't damage the engine before I try testing it? Obviously the ignition coils will all be disconnected.
Old 09-18-2017, 11:26 AM   #14 (permalink)
Engine-Off-Coast
Natalya's Avatar
Compression looked good on all cylinders, highest was 165 lowest was 152. Going to take apart the upper part of the car again to get back at the knock sensors. Will test for corrosion on the block and shorts within the sensors themselves.
Also, unless anyone thinks it's a bad idea, while I still have the spark plugs out maybe I can spray some carb cleaner down in them to loosen some buildup if there is any, but I kinda doubt its bad at this point.
Old 09-21-2017, 02:14 PM   #15 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Compression sounds fine.
If you are going to loosen buildup, make sure you get it all out. You don't want it coming out when the engine is running.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 09-22-2017, 02:22 PM   #16 (permalink)
Engine-Off-Coast
Natalya's Avatar
Any tips on that? I've never done this before.
Old 09-23-2017, 01:51 PM   #17 (permalink)
Engine-Off-Coast
Natalya's Avatar
Air intake chamber is removed once again. I used my multimeter to perform 2 tests on each knock sensor, both passed both tests. However, I think I'll replace them both anyway with new OEM ones and just eat the cost.
Anyway, before I do it, is it safe to spray carb cleaner into the cylinders through the spark plug tubes? Also the valves are exposed right now... is it safe to hit them with that stuff, or will it cause problems when I start the engine in a week when it's all put back together?
