Old 09-30-2017, 04:52 AM   #10 (permalink)
oil pan 4
If you run water injection during cruise or light load you will likely loose fuel economy.
The insite is a gasoline engine so to regeneration the NOx catalyst the ECU can just riches the air fuel mixture. The NOx will turn back to nitrogen and oxygen all on its own, eventually.
