Old 03-18-2018, 10:20 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mort View Post
This the symptom of a bad ground.
-m
I wondered about some sort of circuit problem like that when I got the bulb out and could see that it's filaments were intact. But if it is a bad ground, then why did the problem go away without a "fix"? Did remove and reinstalling the bulb somehow clear a grounding issue? I did not clean any connectors. Should I expect the problem to come back if it is a ground issue?
